Hi all
I'm using the TF in full stereo with a Chapman Stick : bass strings are processed with the A input, and higher strings with the B input.
When I'm using a preset with a delay on B and no delay on A, but with some modulation, I hear the modulation on both inputs, even the one without delay. I thought the modulation were on the trails of the delay only. I'm wrong?
This makes the TF unuseful for me in this configuration, because I don't want necessarily to hear some modulation on the input withourt delay. Could it be possible to add a feature on the next update to begin the modulation only when the delay has more than 1 ms delay time (and thus, when you're at 0 ms, there's no delay and no modulation)?
Thanks in advance for your reply
