TF version 5- possible bug in Aux Sw K0 ?
Home Forums Products Stompboxes TF version 5- possible bug in Aux Sw K0 ?
Viewing 4 reply threads
    • #112171
      EdDrake
      Ever since updating to the last TF beta and then the newest version 5 update I can't get my 3 button Aux switch to work properly with K0.  I have tested my TRS cable with a multimeter and it's working fine. I like to program one of the 3 switches to toggle between a lower wet setting and a higher one which has been working fine for years. I tried using the Ring to trigger K0 which is how I've been using it. I can set the min value and the max value but when I go out of System mode back to bank mode it will work one time on the current preset but when I switch to a different preset it won't work at all. Thinking maybe one of the foot switches is faulty I switched K0 to be triggered by the Tip of the switch and I get the same exact behavior so now I'm beginning to think there's a bug.
      Can someone confirm whether Aux Sw works with K0 as it should or is this a bug? If not please tell me what I'm doing wrong. I only use a few of the Aux Sw options and the other ones are working fine just not K0.
      Also I really wish after every software update I didn't have to reprogram the pedal with the Aux Sw, kill dry, byp typ settings etc. In other words when I back up my settings and restore the pedal, I want ALL of my settings restored, everything. Once I restore the pedal it should be ready to use and I shouldn't have to spend any more time programming it to get back to the state before I updated the software which is a real PITA. Could this be possible in a future update?
    • #127212
      EdDrake
      Can anyone confirm if Aux Sw is working? Specifically K0?
      Thanks
    • #127213
      gkellum
      We'll check and let you know.
    • #137846
      gkellum
      Ok, it seems to be working fine for us unless you've enabled Catch-Up mode for the knobs. Do you have Catch-Up mode enabled?
    • #137847
      EdDrake
      YES!!!
      That's it! I need to write this stuff down because when it's a long time between software updates it's easy to forget. Of course if ALL of my settings were saved when I back up I wouldn't have to 😉 (hint, hint)
      Thank you very much!  Merry Christmas!!
