Thanks to Jerome at support – H9 Plugin issues
Home › Forums › Products › Plug-Ins › Thanks to Jerome at support – H9 Plugin issues
    • #116233
      makzimia
        Hi all,
        Just wanted to make a shout out to Jerome, although I am sure he is very busy, solved my issues with H9 Bundle not all showing up in Studio One Pro 5.1.1.
        For all those who ever have an issue that shouldn’t have happened missing plugins that just don’t show up…
        This is the actual fix if you have everything correct otherwise.
        navigate to C:Users<username>AppDataRoamingPreSonusStudio One 5 and move the x64 folder there to the desktop. Then start Studio One. This should prompt a rescan of all plugins.
        Cheers,
        Tony
      • #156520
        joeydego
          makzimia wrote:
          Hi all,
          Cheers,
          Tony
          Would this have worked by simply scanning for new plugins upon startup?
        • #156521
          makzimia
            Sadly no. Nothing had worked :). If you saw the chain that led to that last step, you’d understand.
