Home › Forums › Products › Stompboxes › The TremoloPan just has a little delay…
April 19, 2019 at 7:02 pm #115291Howie WangParticipantHi,
As I was setting a TremoloPan preset on my H9, I found there is a problem with the pedal. When I change another effect to the tremolo, it seems that the effect doesn’t start from the note I play, sometime there is a little delay, but sometime it goes well. As the effect is set to a square wave trem, it is a true disaster when it doesn’t sync to the song’s tempo.
At first I think it may be something wrong with my Boss ES-8 system so I remove the H9 out of it but the problem is still there.
Can anyone help me about this issue?Thanks a lot!
April 21, 2019 at 7:53 pm #151768camnParticipant
Can we hear it?
April 22, 2019 at 6:41 pm #151776Howie Wang wrote:
As I was setting a TremoloPan preset on my H9, I found there is a problem with the pedal. When I change another effect to the tremolo, it seems that the effect doesn't start from the note I play, sometime there is a little delay, but sometime it goes well. As the effect is set to a square wave trem, it is a true disaster when it doesn't sync to the song's tempo.
Hi Howie,
You may have your Boss ES-8 send a CC to your H9 when you switch to the TremoloPan algorithm, and map this CC to "TAP". Hitting Tap once can restart the tremolo.
April 30, 2019 at 3:31 am #151821Howie WangParticipantbohan wrote:Howie Wang wrote:
Hi Howie,
You may have your Boss ES-8 send a CC to your H9 when you switch to the TremoloPan algorithm, and map this CC to “TAP”. Hitting Tap once can restart the tremolo.
Will try it, thanks a lot!
