Home › Forums › Products › Stompboxes › third H9, big volume drop
December 27, 2016 at 8:41 pm #113904Jan GeertsMember
it’s obvious I love the H9, since I just got a third one. When it’s in the chain however, there’s a huge volume drop.
What can I do about it, please?
best
Jan
December 27, 2016 at 9:37 pm #145262
Need a bit more information – it's not obvious how you are set up. Since this is not normally an issue, it it presumably a factor of how your units are connected and configured.
A question – you say you have 3 H9's – is this problem common to all of them or just one ? If you re-order them, does it change things ?
December 28, 2016 at 10:10 pm #145270Jan GeertsMember
No problem with the other two. With the new one first in the chain of 3, there is the drop. I will swap them tomorrow. Also, it’s b stock and already registered. I have mailed support to deregister it, so I can edit it with the ipad. Maybe that will shed some light.
Could too many buffers be what’s causing this?
There are some drive pedals in front of it.
Tx
Jan
December 30, 2016 at 12:44 am #145284Jan GeertsMember
So I swopped. This unit is responsible for the drop. Now I’ve got it connected I could check the input meter, and it’s low. I raised the level to max, still a volume drop, the meters don’t even go into orange. Any suggestions?
December 30, 2016 at 2:50 am #145286
I would suggest that you fully re-initialize the unit as described in the UM. If the problem continues, support@eventide.com
December 31, 2016 at 5:23 pm #145300Jan GeertsMember
still the same problem, I’ll contact support.
July 31, 2017 at 7:23 pm #146907roverdogParticipant
I have the same problem, running between an ADA MP-1 and an ENGL 820 power amp. No drop in volume when used in front of the preamp.
Trying to use the stereo capabilities of the H9 live.
Thanks
