Time Factor: Adjust Wet Signal Level, suggestions?
Home Forums Products Stompboxes Time Factor: Adjust Wet Signal Level, suggestions?
Viewing 3 reply threads
    • #181492
      Ampmadscientist
        Set the mix control to 100% dry, the output of time factor is unity to the input signal.
        Set the mix control to 100% wet, the output of time factor is more than 2X unity, to the input signal…
        The wet signal only, is a “boosted signal”, not unity gain.
        This creates a level problem for the effects loop in a guitar amplifier. The wet signal boosted (as it is) far beyond unity, will cause the effects return to reach a point of clipping.
        If dry signal = unity, and if wet signal could be = unity
        The wet and dry can still be balanced appropriately by the mix control, without boosting the wet signal.
        It’s a DSP processor, there should be a way to control the wet signal level. You can control “anything” with a DSP….or you should be able to.
        Do you know if there is any way to control wet signal level only? (master effect only level control)
        Any software you know of?
        Any adjustment available in the pedal that you know of?
        Thanks in advance for any pointers, it would sure help this efx loop if there was a solution. Appreciate your input very much. AMS
      • #181644
        ndeshpande
          This could be caused by a few things… you haven’t mentioned your set up, aside from that this is in the effects loop of a guitar amp. There’s lots of variety in gain levels of amp effects loops, varying from brand to brand and even model to model. My first recommendation is that you check what level (instrument/-10 consumer line/+4 pro line) your effects loop is expecting, and setting the Time Factor’s instrument/line level switches accordingly. If your effects loop only operates at +4, that might require you to use line level shifters between your effects loop and time factor. Differences in wet and dry gain might be caused by hitting the front end of your Time Factor too hard. Pages 16 and 18 of the Time Factor manual respectively cover setting input monitoring levels to help you probe that you’re hitting the analog inputs with too much volume, and using Input and Output swell. I think you could use the latter as a last resort to set your wet levels, given you set up your Time Factor correctly.
        • #182658
          Ampmadscientist
            What causes it? It’s built that way from the factory.
            The wet output level is boosted no matter what the input level. The wet output level is never unity with the input.
            The input output level switch are set to “line level”…
            But in this instance our input level is 3V PP (+12) it does the same no matter what input level is used. I’ve tried all different input levels.
            And, we tried (my friend’s) a second time factor unit (with updates installed), and it does the very same thing. So this is not a defect in the unit.
            We are looking at these levels on an oscilloscope, there’s no mistake here. It’s built that way.
            I find it very hard to believe that this never occurred to anybody: it’s obvious to anybody who measures it.
            The level of the wet output is more than 2X input level, not unity.
            If you want to make this compatible with an effects loop, the wet needs to be unity, not boosted.
            You need to make an update for this pedal, that fixes the wet level problem. It’s a DSP; if you have the software you can do it.
          • #182664
            ndeshpande
              Let me preface this with: I’m here to help you get your system up and running so you can access the sounds you know are inside the Time Factor. I’ll leave my comments on the tone of your wording brief, but I’ll mention that your approach is not a productive path in getting our help. You either didn’t read through my last response very carefully, or you would rather complain about an issue than fix it – I pointed you to pages in the manual which can help you diagnose, adjust, and potentially solve the problems you are seeing in your set up. Further, insisting that things “just be fixed” to your specific use case and assuming that we haven’t run test signals or have never used an oscilloscope on our products is extremely presumptuous. If I didn’t have more patience, I’d interpret this as extremely disrespectful and stop engaging with you right here.
              But I understand you are frustrated, and I understand that the more technical aspects of gear can be infuriating… for the time being, in spite of all this you have my sympathy. You’ve purchased a Time Factor – a very fine unit I’ve had on my pedal board since before I started working for Eventide – and as a fellow musician that loves the Time Factor, I’m compelled to help get you up and running, because I’m excited for you to discover the infinitely deep sounds waiting for you.
              Every single audio set up requires proper gain staging. There’s a reason guitars, synths, stompboxes, amplifiers, buffers, etc. all have a volume knob (and in some cases have separate input and output volumes, or gain and master volumes). It is important to know what the nominal signal level is at each stage of your signal chain, what the output of a given block is sending, and what the input of the next block is receiving. Overloading any one stage can cause distortion, or volume mismatches such as the ones you are experiencing.
              Once again, amp effects loop are extremely varied. Some amp manufacturers set their loops up for DI outs, others for consumer line level, more for pro line level, and even more for instrument level. There are passive effects loop, active effects loops, effects loops with only a driver stage, effects loops with only a recovery stage, solid state effects loops, tube effects loops, transparent effects loops, colored effects loops – all of these have different levels and gain stages. These all impact the amount of signal going from the send and to the return. You still have not told me what amp or effects loop you are running, and as a result both of us are shooting in the dark here. All I can gather is that you are frustrated that your Time Factor doesn’t work with an effects loop that you happen to own. Heck, I don’t even know if you have a solid state or tube amp yet, because you’ve only told me that the Time Factor should just work in your effects loop.
              You observe that your set up has this level mismatch with multiple Factor pedals. While you’ve jumped to the conclusion there is a defect with Eventide Factors, I encourage you to take a step back and think about your set up. 3V P-P at +12 dB is a very hot signal, well above pro level +4 dB Line Level and significantly above consumer level -10 dB Line Level (not to even mention guitar effects level at -30 to -20 dB). The Factors, as you observe, can handle the signal, but if you overload and saturate the input to an effect it is expected that the nominal output level of that effect will also be pretty hot. Additionally, not only are you overloading your input signal, but the Time Factor is preventing you from overloading/destroying your converters and further amplification stages/speaker by insuring you don’t slam the next stage with extremely hot voltage. We’ve massively overbuilt the Time Factor to handle abusive levels, such as what you are presenting. Your observation of surprise that more people are not experiencing your behavior is an astute one – this isn’t to suggest that you don’t have a problem, but rather I suggest you reconsider aspects of how you have set up your system, and what voltage level you are hitting your Time Factor with. I’d be surprised if other effects units didn’t have similar or worse behavior to what you describe under the conditions of your set up.
              I encourage you to read through the Time Factor manual, specifically the bits on setting input and output levels. Additionally, you may be able to take advantage of the swell features set to a constant level to help cool the input signal. I pointed you to these pages in my last post, and I once again encourage you to read through them. You can monitor your input levels, and that can be useful for diagnosis of your levels as you can see how much signal the Time Factor is getting, relative to its headroom. Another solution is to pad/attenuate the signal down before hitting the Time Factor – there are Line Level shifters that may help you here, or a good buffer with attenuation can help – then boosting after the fact, which can be done on the Time Factor itself using output gain to a certain extent. Once again, I refer you to the same pages in the Time Factor manual I cited in my last post.
              To help reinforce your understanding of how the Time Factor is set up – and that the unity gain behavior you expect is in fact programmed into the pedal – I encourage you to test the following: plug a guitar directly into your time factor, set the input/output level switches to Guitar/Amp, plug Time Factor directly to the input of your amp, set up your amp to be relatively clean, and start playing through your Time Factor. Modifying the wet/dry mix of the unit should produce the unity levels and a more balanced wet/dry level that you are expecting. This happens because you’re supplying a voltage level to the Time Factor more in line with its gain staging, and it will respond accordingly. If you still experience unbalanced wet/dry signasl and your wet output at 100% is well below unity gain in this scenario, I encourage you to get in touch with our support line at support@eventide.com
