Time Factor and Looper via MIDI
Home Forums Products Stompboxes Time Factor and Looper via MIDI
Viewing 5 reply threads
    • #186831
      Telegirl
      Hi
      Does anyone know what the MIDI control numbers are for the Time Factor Looper for record, playback, stop, and empty? I want to be able to use the Looper via my MIDI controller.
    • #186844
      There are no default MIDI CCs for any of the TimeFactor controls. These are all customizable by the user.
      You can find details about making these mappings using the pedal UI on page 51 of the manual: https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/TimeFactorManual.pdf
      I would suggest using the H9 Control app and going to Pedal Settings > MIDI Settings > Assign MIDI messages to pedal functions and mapping the controls that way. https://www.eventideaudio.com/software/h9-control-app/
    • #186846
      Telegirl
      I’ve mapped the CCs, but it isn’t working. Here are my settings:
      Looper Rec: 87, Program Change 8
      Looper Play: 86
      Looper Stop: 85
      Looper Empty: 90
      Looper Rev: 95
      Looper Octave: 94
      In the Morningstar, I have a button labeled Looper On and it has PC 8 and CC# 87, CC Value 0, MIDI Channel 1. When I push the button, it turns the Time Factor to the Looper, but it doesn’t seem to record. Is there a value I need to assign to get it to record?
    • #186850
      Yes, all of those values should be 64 or higher to trigger the action.
    • #186851
      Telegirl
      That worked. Thank you!!
    • #186853
      Good to hear!
