Time Factor Bank Down option
Home Forums Products Stompboxes Time Factor Bank Down option
Viewing 3 reply threads
    • #107691
      I just got my Time Factor and was wondering if there is a way to "Bank Down" instead of having to scroll through all the banks.
      If I have 10 banks and want to go from 2 back to 1, I have to scroll through all the banks. If I go to far by accident….well you get what I mean. Could be a pain on stage.
    • #121669
      rabiddiabetic13
        get a 3 button aux switch and set one of them for bank down.  It's all in the manual how to set it up.
      • #121670
        Thanks, I saw that after I posted….My Bad!. Can I just use a single button set up? I have a spot for one button.
        I am not sure I will even need it. I set up 3 banks for right now. (I have only had it a couple of days) but i will probably end up with at least 5 which is still easy to scroll through.
      • #132893
        rabiddiabetic13
          yes you could use a single button ( it would be Tip out of the three choices the others being Ring and Tip&Ring)  Just remember it needs to be  momentary contact normally open switch.
