Time factor delay A not working
Home Forums Products Stompboxes Time factor delay A not working
    • #112722
      filipe mello
      Delay A of my timefactor stopped working does anyone knows how to fix it…?
    • #139900
      Can you explain what you mean by "not working ?"
      If you have a stereo rig, and it is not coming out of one channel, have you tried swapping the outputs ?
      • #139908
        filipe mello
        nickrose wrote:
        Can you explain what you mean by “not working ?”
        No, i run it on mono!! today the delay A is simply not working…only delay B can be heard!! Everything was set as i usually do, but when i turn the A+B knob to only A there s no effect in it….it happens with all types of delay….now only delay B is working.
    • #139911
      filipe mello
      Thank u guys, this morning i changed the inputs and it started working again…..i made a mistake cleaning my board and plugged in on the stero side…everything fixed now…thanks a lot
