time factor display blinking “<-- TURN"
Home Forums Products Stompboxes time factor display blinking “<-- TURN"
    • #106685
      taylor12k
      in Looping mode, i can't get the TF to stop blinking "<– TURN".. no matter what i turn..
      how do i get this to stop!? thanks!
    • #119591
      In  looper mode, when you have recorded a loop catchup mode is enabled on Dly Time A (Loop Start Point) and Dly Time B (Loop Length) and this is what you are seeing. One of these is probably sitting on the fence and causing the catchup display to be visible. If you wiggle both these knobs it should stop.
      If this doesn't fix it, it may be a bad contact on obe of these controls which would require service – contact your dealer or support@eventide.com in this case.
    • #119592
      taylor12k
      thanks, i'll wiggle those knobs some more..
      two other questions while i'm here:
      – my decay knob doesn't go lower than "2".. shouldn't it go to "0"?
      – also, my pitch increment can only be set to "octave".. as much as i turn the knob i can't select or see any of the other pitch intervals…
