Time Factor Freezing
Home Forums Products Stompboxes Time Factor Freezing
    • #111208
      Has anyone had their TF freeze,…maybe when trying to save a setting, or after down loading your saved presets?  To "unfreeze" the unit I would have to unplug the power..thus losing my presets:( Any suggestions would be greatly appreciated.  Don
    • #125028
      No. Have you checked your power supply?
    • #125029
        They should not do this. As the man says, check the power supply, If that is good, it is probably a hardware issue – contact your dealer or support@eventide.com
