On my TIme Factor I typically set the wet/dry mix and tempo globally and I notice on some of the new presets this mix setting is changing on each patch so the global mix setting is not working as expected. I noticed this because some of the new presets are %100 wet and since I set my mix globally this shouldn't be the case unless there is something I don't understand about this global setting. I checked that I do have the Global mix setting turned on. Also I didn't think to check the global Tempo setting last night when I was playing and I'm at work right now so I won't have a chance to look at that until tonight. I will report back later.
