Home › Forums › Products › Stompboxes › Time Factor: It sounds when turned off even in DSP bypass mode
Hi all
My TF lets the sound pass through the outputs when the pedal is turned off, even if DSP bypass mode is activated. This is supposed to happen only when RELAY bypass mode is activated, isn’t it?
When it is turned off it does not know to what the bypass mode is set (or indeed anything else). So, for safety, it always goes to relay bypass.
OK, thanks a lot!
