Home › Forums › Products › Stompboxes › TIME FACTOR MIDY BYPASS WITH PROGRAM CHANGE
August 3, 2009 at 5:26 am #106357florindoParticipant
Hi ,
I need to controll the onoff Time factor by pass function with midi controller but my midi controller not support the Midi CC so i need to onoff the by pass with Midi Program Change.
Please help me for a solution
for example in pitch factor is possible controll via midi the onoff bypass with Midi Program Change, why not in tome and mode factor?
Thank you
August 3, 2009 at 7:36 pm #118879oyarsaParticipant
The Time Factor will allow control of the Bypass/Active function through the use of MIDI continuous controller numbers 0 to 99, or by use of the MIDI Pitch Bend, but not through MIDI Program Change messages.
Program Change messages are used to switch banks.
Hopefully your MIDI Controller can send pitch bend or at least some continuous controller messages.
August 3, 2009 at 8:11 pm #118880florindoParticipant
no,
unfortunately my pedalboard support only progrma change.
however the pitch factor support onoff with program change ..
August 3, 2009 at 8:56 pm #130001oyarsaParticipant
Have you considered using Aux Switches?….It appears that Toggle Bypass/Active is controllable via these switches…….or, perhaps upgrade to a more comprehensive MIDI Controller.
As a keyboardist, my instruments handle all the MIDI implementation, but I can see you may need to upgrade…good luck!
August 4, 2009 at 8:17 am #118881florindoParticipant
For the eventide staffsupport:
why the Pich mode can be onoff bypass with Program Change and Time and Mode Factor not?
would be sufficient a litte software upgrade for add this function as well the Time and Mode
wait you reply
thanks
