Time factor mix
Home Forums Products Stompboxes Time factor mix
Viewing 4 reply threads
    • #113778
      steve collop
      I have a question about the mix control. I have a prs going into the pedal and out to front of amp. Both switches are set to guitar . The reverbs or delays wet dry mix cannot be set more than 3 or 4 without being overpowering. The green light never lights up to show input . Is this normal ?
      Thanks for any replies.
    • #144722
      Not sure what a prs is. That aside, my guess is that you have a very low input level (as suggested by lack of green), maybe for cabling reasons. As a result, any output from the pedal seems excessive.
    • #144724
      steve collop
      PRS is a guitar, I have an ordinary guitar cable from the guitar into the TF. I have a multicore from pedal board to the amp bit I am just going simply from guitar to amp in this instance ? to see why the efx is so strong ,I would have thought hitting green on the mix led would be the correct signal level and then adjust return level on my amps efx loop to taste but it does not get anywhere near there without being unusably strong with delays feeding back as if they are set to 100% .
    • #144729
      Note that some presets have delays with feedback controls. These can give 110% feedback which can get loud. Check the settings.
      If it is not the above, can you re-init the unit (middle footswitch and encoder at power up) ? This will delete any user presets. Then connect  guitar-tf-amp with ordinary mono cables. See if this changes anything.
    • #144794
      steve collop
      Had a new Ribbon cable sent for free…many thanks It has fixed all these issues .I have made an Aux switch, if i understand correctly I can programme three switches for example B+ tap and say bypass which work with general patches and then when I am in loop they have a different function ?
