Time Factor mono to Stereo routing
Home Forums Products Stompboxes Time Factor mono to Stereo routing
Viewing 3 reply threads
    • #170835
      nicklaus_rohrbach
      Hello !
      I’m using the Time Factor with 1 amplifier and 2 guitar effects lines for 1 guitar.
      So the guitar signal is split (dynamically with a stereo crossfade pedal) so as to feed the 2 effects lines.
      The 2 effects lines get processed seperately in the Time Factor and fed to the left output to the Amplifier.
      It all works fine when the preset is on BUT when bypassed, I only get one line (the first) to the output.
      I would like the two inputs to be merged when bypassed as well.
      I’ve read the manual a hundred times but could not find the info as how to do that (or IF I can do that)
      Does somebody know how to achieve that ?
      Thanks a lot !
    • #170931
      Sorry, the TimeFactor will not sum the stereo inputs to a mono output when the pedal is bypassed. As a work around, you could adjust the mix value to 0 instead of bypassing the pedal, and this will preserve the mono summed signal.
    • #170964
      nicklaus_rohrbach
      Thanks
      But it’ not gonna work for me
      I need the unit to work as a Stomp Box (which it is) meaning I want to bypass the effects using the footswitch while I’m playing – I’m not gonna move some knob on the floor 🙂
      I’m gonna try to sum both outputs with a Y cable.
      I’ll tell you if that works
    • #170971
      A Y-cable is not the best way to sum a stereo output pair. You’ll want a device that properly sums the stereo output to a mono signal.
      Alternatively, you can get an aux switch or expression pedal and map that to the mix control.
