Home › Forums › Products › Stompboxes › Time Factor: OUTPUT 1 less volume than OUTPUT 2 when in stereo
- This topic has 11 replies, 3 voices, and was last updated 1 year, 7 months ago by bohanEventide Staff.
September 12, 2015 at 9:55 pm #112842DG_SanzMember
Hi all
I’ve recently started using two amps at gigs. I love the rich and full sound that comes out of Time Factor when running in stereo.
However, I’ve noticed that, when running it in stereo, OUT1 delivers less volume (about 3dB less) than OUT2.
This happens no matter if the preset is active or inactive. Even with the pedal turned off it shows the same behavior.
I’ve tried switching cables, nothing. I recorded directly from both outputs into a DAW. Nothing again.
It seems that OUT1 delivers less volume that OUT2 when using the pedal in stereo.
This doesn’t happen when running it in mono. In mono, each OUT has the same level, I tried it.
Any possible solution?
Thanks in advance
September 14, 2015 at 5:38 pm #140560gkellumParticipant
Are you running a stereo signal into the TimeFactor or a mono signal? When you look at the input and output level meters in H9 Control (for instance), do you see the level difference there that you're hearing?
September 15, 2015 at 10:33 pm #140580DG_SanzMember
Thanks for your reply.
I’m running a mono signal. And yes, the bumeter in H9 control app show one channel is quieter than the other. -
June 9, 2018 at 9:02 pm #149459ulrichandersParticipant
I’ve got the same problem, less signal on one of the two outputs and I’m running a mono signal in my Time Factor (guitar–> TF–> stereo out to mixer). How to solve this?
August 18, 2019 at 5:01 pm #152559maxigtrMember
Hello, i have the same problem. but using all in mono, i connect guitar to imput 1 and put the output 2 direct to the amp, and the volume its higher. why this? thanks
Is the effect on or not? What is the value of the Delay Mix knob?
August 19, 2019 at 3:55 pm #152566maxigtrMember
It happen with the TF in ON and OFF. And no matter dly mix were. All in A or all in B its the same. Output A have less volume
August 19, 2019 at 5:38 pm #152569maxigtrMembermaxigtr wrote:It happen with the TF in ON and OFF. And no matter dly mix were. All in A or all in B its the same. Output A have less volume
Output 1 sorry
If you connect your TF to your PC/Mac, and open the level meters in the “Pedal Settings” screen of the H9 Control, can you see the difference between 2 Output channels?
August 9, 2022 at 5:37 pm #164961mefifeParticipant
Same issues as above. meters in the app look fine, but left output is significantly lower.
July 8, 2023 at 11:29 am #172341MateiraduParticipant
hey, I have the same problem with a Timefactor bought just this week. Why is this happening and how I can solve this?
July 9, 2023 at 9:31 pm #172355
Have you tried reinstalling the software in Eventide Device Manager?
