Time Factor Reverse not working properly
Home Forums Products Stompboxes Time Factor Reverse not working properly
Viewing 3 reply threads
    • #109455
      Myujishan
        I'm having an issue when I switch from a Reverse preset to a preset of another type (Digital Delay let's say) and when I go back to a Reverse preset the mix is totally dry… BUT when I move the wet/dry knob a bit, it comes back in. This is across all of my Reverse presets, and only started happening after I updated. Thoughts/similar problems?
      • #124159
        ndeshpande
          Is the preset's mix set to 0% wet (100% dry)? Also, which version of the software are you running?
          Thank you,
          Nikhil
        • #124179
          Myujishan
            Nikhil,
            The preset is 100% wet. But I'm also noticing it across the other effects/presets, not just Reverse (with wet mix rangin from 3% to 100%). It will just randomly be a dry signal, then if I switch presets (say from 2.1 to 2.2 then back to 2.1) it will be ok again. And I have catchup enabled, so I know it's not due to accidentally bumping the mix knob.
            I'm running 3.5.0 (4)
            Thank you,
            Jeff
          • #135132
            ndeshpande
              It shouldn't be happening accross multiple algorithms… back up your presets and initialize the unit. If that doesn't work I'd suggest contacting support@eventide.com. I'll see if I can't think of anything else it could be in the meantime as well.
              Thanks,
              Nikhil
