Home › Forums › Products › Stompboxes › Time Factor – Type B port USB converter to Bluetooth
October 19, 2020 at 12:41 am #116150jodacrockerMember
I want to know if it is possible to used a converter from USB Type B port to bluetooth, in order to connect the TimeFactor wireless to the tablet or celphone with H9 Software.
Someone have tried this?
October 21, 2020 at 12:09 am #156101
Sorry, no.
To drive the Bluetooth requires a huge amount of software, which a product developed before Bluetooth existed does not have.
October 21, 2020 at 2:01 am #156102jodacrockerMember
This will be a really good upgrade for the next SW release.
Eventide could sell the converter for bluetooth as accessory for StompBoxes.
October 21, 2020 at 1:07 pm #156104
Actually, if you want to use your TF as a Bluetooth LE peripheral, Yamaha makes/used to make a DIN plugin (MD-BT01) which should do it. Haven't tried it, however.
October 24, 2020 at 12:08 am #156129
Look on eBay – there are lots of them. But, it does seem to be discontinued, which makes it a bit experimental.
You will also need to make sure that your unit supplies MIDI power – see post at top of Stompboxes column.
I look for Yamaha MD-BT01, but I can’t find this available.
I througth that Eventide needs to see the impact of Port Type B to Bluetooth converter.
This will take the Eventide stompboxes to the next level.
