TimeFactor 2.0 beta
Home Forums Products Stompboxes TimeFactor 2.0 beta
    • #105283
      When I first got my TimeFactor, I plugged in my Boss FS-5U switch into the aux jack and it worked for tap tempo. That's exactly what I wanted. With the 2.0 update, the aux switch sets turns RPT (repeats) off and on. I changed the aux switch setting to TAP and saved but it still triggers RPT.
      Has anyone else seen this behavior?
    • #116824
      Found the answer to my own question. They added the ability for the aux switch to control the three onboard buttons. By default these are set. I ended up having two functions assigned to my aux switch and RPT won out. The solution is to clear the extra switch assignment.
