Home › Forums › Products › Stompboxes › timefactor and 2 fx loops amps
March 12, 2011 at 8:46 pm #107717
kanifi
Memberhello,
i would like to know how to plug my timefactor in stéréo into 2 FX loop amps
i guess ill have to use timefactor IN 1 to send amp1 and OUT 1 to return amp1 then IN 2 to send second amp OUT2 to return of the second amp ?
easy like this ?
thx
March 12, 2011 at 10:28 pm #121720
usehername
MemberYes I think that is exactly how the manual suggests setting it up. Works great for me. Amp1 preamp controls the tone. Amp 2 is power stage only.
March 12, 2011 at 10:41 pm #121721
timothyhill
MemberYep, that's one way to do it. Mostly, it depends on whether you're using the sounds of both amps at the same time, or if you're using the sound of one and using it to drive the other amp.
If you're using both amps to get your sound:
Amp 1 Send >> TF In 1 >> TF Out 1 >> Amp 1 Return
Amp 2 Send >> TF In 2 >> TF Out 2 >> Amp 2 Return
If you're using one amp to drive the other:
………………………..>> TF Out 2 >> Amp 2 Return
March 13, 2011 at 4:40 am #121725
kanifi
Memberthx for your help
ill try both
March 14, 2011 at 4:08 pm #132952
oinkbanana
Member^^^ If we set it up that way would some effects might cause cross talk from In1 to Out2 and In2 to Out1?
March 14, 2011 at 9:03 pm #132953
timothyhill
MemberPotentially, but only in the effected signal. The dry signal would not be mixed together. A lot of the effects are true stereo, too, so it would depend on what effects you're using and how you've got them setup. I think the best thing to do is to try it both ways and see which you like best.
As examples, in my practice rig, I've got a MB Mark IV combo feeding my pedalboard, which then goes back into the return on the main amp and the return on another MB combo. In this case, I'm driving both amps with the primary Mark IV.
In another rig, I've got a Marshall DSL and a VHT CL50 running in parallel. I feed my pedalboard from the sends of both amps, which goes back into the returns of both amps. In this case, each amp is contributing to the sound. Channel switching is done via MIDI with a custom cable for the VHT (the DSL uses 1/4" jacks).
