TimeFactor and MIDI Clock
Home Forums Products Stompboxes TimeFactor and MIDI Clock
Viewing 6 reply threads
    • #107010
      So I just got a midi switching system and I need to sync up a few pedals tempo wise.
      So here's what Im wondering:
      Lets say i send a program change to the TimeFactor from my midi controller.  The program change tell the TimeFactor to load a specific bank-patch.  That patch has a specific tempo.  If I in turn want the TimeFactor to send that tempo out as midi clock via the midi out, how do I do that?
      Also if I wanted to the TimeFactor to send that tempo out of the midi out as CC messages, is that possible?
    • #120252
      achaput
        In the MIDI menu of System mode, set CLK OUT to ON. Then the TimeFactor will transmit MIDI clock of the tempo saved in any preset.
        You can connect an aux switch to TimeFactor and have that transmit MIDI CC messages. If the device you're transmitting to can interpret those messages as tempo, then you should be able to tap MIDI tempo on the aux switch.
      • #120275
        Note that due to a bug in the current firmware, the MIDI clock tempo out of the TimeFactor will not change when you change presets. You need to tap the tempo again for it to change.
      • #131467
        wow, is that really true??
        If so, that makes this pedal pretty useless for me.
        Can I use an older version of the software and be ok?
      • #125168
        alexworkman
          Here are a few videos that show this bug. Any help would be appreciated.
          https://vimeo.com/32542838
          https://vimeo.com/32543006
        • #135957
            dack:
            This will be fixed in the next release, due in the New Year.
          • #136473
            Does anyone know if this issue has been fixed yet?
