Timefactor bank selection
Home Forums Products Stompboxes Timefactor bank selection
    • #111369
      RobCrowdy
        Hi-
        I am happy incrementing banks (and decrementing via an Aux switch) but I'd like to scroll through faster sometimes. I know it has something to do with the encoder knob but I just can't do it. The software update text doesn't help me:
        Bank Select via Encoder Knob
        In Bank Mode, the Encoder can now be used to select banks in either
        direction if turned within 2 seconds of pressing a bank change
        footswitch.
        I can't make this work (what is a "bank change footswitch"- the right footswitch?).
        I feel like I'm missing something very obvious- can someone point me in the right direction?
        Thanks- Rob.
      • #125369
          There's not much more to add.
          If you press a footswitch that changes and displays the Bank number (e.g. right switch in presets mode), and turn the encoder within 2 seconds, you can adjust the bank up or down. If you stop turning the encoder for two seconds, it will return to normal operation. This is just like the way you can do a fine adjust of tempo or knob parameters.
        • #125375
          RobCrowdy
            That's great- thanks. In Bank mode, hit right hand switch to pick a bank then within two seconds scroll using the encoder. In any other state the scroll is through effect types..
            Cheers- Rob.
