There seems to be a short dip/dropout when engaging bypass on the timefactor with most recent software update, however not when changing from one preset to another. So if I had a completely dry preset on the timefactor, and used that instead of bypass it would be seamless.
On the pitchfactor the DSP bypass is completely seamless. No dropouts or odd noises at all..
Curious if others are seeing the same thing, and if the a better bypass might be in the upcoming TF update, as it works flawlessy in the PF.
