Home › Forums › Products › Stompboxes › TimeFactor–Bypass not accurate?
Why would the timfactor in by pass mode still sound affected? It sounds like my guitar is in a tunnel. Used the effects loop on my Mesa dual rectifier? Any suggestions. I just got the pedal and the power is amazing but I need to bypass at times.
Hi rlab777,
My guess would be that you Dual Rectifier has parallel effects loop and you have Time Factors Kill Dry option off.
If that is the case, turn Kill Dry on in the system menu under bypass choices and it should clear your problem right up.
