Timefactor – Can’t change parameters
Home › Forums › Products › Stompboxes › Timefactor – Can’t change parameters
Viewing 3 reply threads
    • #116201
      Hi, so maybe a dumb question but I’ve been through the manual, updated firmware, “knobs” are set to normal, but regardless of setting, when I turn a control knob, it doesn’t change anything, nothing shows on the billboard besides the effect or preset name.  So the presets work fine, but I can’t change any setting on any effect… am I missing something?  For what it’s worth, I’m coming back to guitar after a couple years off, so I may be overlooking something obvious, not that I ever learned how to use this box in the first place. wink
      Thanks,
      Russ
    • #156331
      joecozzi
        Hi Russ, if you’ve already updated the firmware, I also recommend conducting a factory reset.
        To restore Factory Presets and all System settings, power up TimeFactor while simultaneously pressing the Middle Footswitch and the Encoder until [INITIALIZING] is displayed.
        See if that fixes the functionality for you.
      • #156335
        bohan
          Are all knobs not working? Does the encoder work? How about the footswitches? It could be a loose ribbon cable in the box.
          It's also worth trying to use a USB cable to connect to a PC/Mac and try if parameters change when you change knobs in the H9 Control app
        • #156340
          Update:  Everything worked through the app which got me thinking about the loose cable suggestion, so I popped the cover off and on, didn’t actually reconnect anything, but now all the knobs and switches are working as expected.  Go figure…  Thanks all!
          Russ
        • #156333
          joecozzi wrote:
          Hi Russ, if you’ve already updated the firmware, I also recommend conducting a factory reset. To restore Factory Presets and all System settings, power up TimeFactor while simultaneously pressing the Middle Footswitch and the Encoder until [INITIALIZING] is displayed. See if that fixes the functionality for you.
          Hi, tried that also, before and after the update.  Same result, my control knobs are just for show.
        • #156339
          It’s also worth trying to use a USB cable to connect to a PC/Mac and try if parameters change when you change knobs in the H9 Control app
          Encoder switch works, foot switches work, but none of the control knobs.  I’ll give H9 a try (new to me) and see if I have any luck there.  Thanks.
