I assume you mean that the foot pedal has no effect. Since you give little information, it's hard to be of help.
Make sure you understand how the pedal is programmed and be sure it is plugged in the right socket. If these are true, try a different pedal, and try your pedal in another piece of kit. Once you have done all these, we will be able to see where the problem lies.
