Timefactor how to set equal repeat volume
Home Forums Products Stompboxes Timefactor how to set equal repeat volume
    • #110985
      csipas
      i want to copy (modeling) my old presets from my EHX Memory Man hazarai delay stompbox. I could modeling almost everything except one things. EHX has a multi tap funcition:
      "Sets the relative volume for each repeat. Setting the DECAY knob to the center (12 o’clock) will make each Repeat playback at equal volume." (EHX Manual)
      So there I can set the repeat volume to be equal during the repeating.
      I like this sound very much, can I somehow modeling this in the Timefactor?
      I couldn't find in the Timefactor manual such a option..
      thanks for the answer
    • #124618
      achaput
      If you want more than one repeat to have the same volume try the Multitap algorithm. There's a Taper control that lets you set different values for repeat curves.
      -Alan
    • #150088
      Mairos
      Hello Csipas! can you give your contact or how to write to p.m.? Want to ask about your post.
      “Sets the relative volume for each repeat. Setting the DECAY knob to the center (12 o’clock) will make each Repeat playback at equal volume.” (EHX Manual)
      I couldn’t find in the Timefactor manual such a option..
