Home › Forums › Products › Stompboxes › TimeFactor input/output levels with Boss ES-8
May 17, 2019 at 2:11 pm #115317
patroclo75
ParticipantHi,
I’m using my TimeFactor in a loop with the Boss ES-8 and I would like to know what is the right settings for the TF input/output level: line or instrument? Thank you!
May 17, 2019 at 2:16 pm #151911
Can't speak for Boss, but usually in a loop you would set the unit to Line level.
Basically, if it distorts on Guitar level, use Line. If there is white noise on Line level, use Guitar.
The ears have it…
May 18, 2019 at 9:44 am #151917
patroclo75
Participantnickrose wrote:Can't speak for Boss, but usually in a loop you would set the unit to Line level.
The ears have it…
Both input and output set to line level seems to give the same output level as guitar/amp settings. While if I put line level (input) and amp level (output) the volume of the delay (mix pot) set to 50% is not equal to the dry signal
May 19, 2019 at 3:28 pm #151921
patroclo75
ParticipantAnyway, these are the Boss ES-8 specs for loops’ input and output, maybe it’s useful to match the correct settings in the TimeFactor:
- Nominal Input Level
- IN 1–2, RTN 1–6, RTN 7L, RTN 7R, RTN 8L, RTN 8R, RTN VOL: -10 dBu
- Maximum Input Level
- IN 1–2, RTN 1–6, RTN 7L, RTN 7R, RTN 8L, RTN 8R, RTN VOL: +18 dBu
- Input Impedance
- IN 1, 2: 1 M ohms (Buffer: On)
- Nominal Output Level
- SEND 1–7, SEND 8L, SEND 8R, SEND VOL, OUT 1/L, OUT 2/R, TUNER: -10 dBu
- Maximum Output Level
- SEND 1–7, SEND 8L, SEND 8R, SEND VOL, OUT 1/L, OUT 2/R, TUNER: +18 dBu
- Output Impedance
- OUT 1/L, OUT 2/R: 1 k ohms (Buffer: On)
TUNER: 1 k ohms
- Recommended Load Impedance
- 10 k ohms or greater
May 19, 2019 at 7:25 pm #151922
Please see my previous comments.
