Timefactor, Intermittent crackle and pop
Home › Forums › Products › Stompboxes › Timefactor, Intermittent crackle and pop
Viewing 4 reply threads
    • #165354
      MikeMullins74
        I’ve had this Timefactor for about 10yrs now and in the last month or so i noticed an intermittent crackle/pops coming through as I play on the clean channel. First I ruled out the amp–disconnecting everything going through the effects loop–no crackle/pops.  Then I replaced every patch cable in the effects loop–no change (still crackles).  Then I started removing pedals in the effects loop chain–when I removed the timefactor, the crackle and pops ceased.  Then, I experimented with changing the BYPASS from “DSP with FX” to “Relay” and also verified the crackle and pops no longer present–until I engaged the pedal output.  I went a step further and powered the Timefactor with a different Eventide PS and the crackle persists.  I cleaned the pots and jacks with electronic cleaner–no change.  So, the issue seems internal.
        Anyone else experienced this? Solutions?
        http://www.recognizermusic.com
      • #165403
          You could also try a reinstalling the firmware on your pedal, or a factory reset. I would suggest emailing support@eventide.com to troubleshoot your issues further.
        • #177945
          rodgecomau
            Hi Mike, I’m wondering if you ever we’re able to fix the issue? I think I may have the same thing going on – crackling only when the pedal is engaged.
            Cheers
          • #184402
            sone
              Hello
              I have exactly the same problem.
              Do you have the solutions please ?
              thank you
            • #184589
                Users who experience this issue should please email support@eventideaudio.com and we can help you there.
            • The topic ‘Timefactor, Intermittent crackle and pop’ is closed to new replies.
