Timefactor issue
Home › Forums › Products › Stompboxes › Timefactor issue
Viewing 3 reply threads
    • #109629
      I am using my TimeFactor along with Pitch and Mod.  I use the Coiks power supply.  Today the switches would not function after working fine.   I unplugged the power and then plugged it back in.  Display said UPDATE and unplugged power again and now I'm back to normal.
      Suggestions please.  Hardware issue?  Software issue?
    • #124334
        You may have a problem with the center footswitch (this is the one that would put it into update mode). Try "wiggling" it a bit to be sure it is not stuck in some way. If the problem occurs again you should talk to your dealer, or support@eventide.com as it may be a hardware fault.
      • #124337
        Thanks Nick.  I did a factory reset as well.  Software is currently up to date as far as I can tell.  Your Facebook page says you are in NYC.  Is that correct?  If so, I will be in NYC in April so could drop off the pedal if I'm still having issues.
      • #135267
          We're in New Jersey, just across the river. If you want to drop it off, call our office (201-641-1200) to arrange.
