TimeFactor Lib setup
Home Forums Products Stompboxes TimeFactor Lib setup
    • #106594
      patrickb
      How do I set up the TF to read/write to the Lib application?
    • #119385
      Nothing you have to do to the TF except to plug in a USB or MIDI cable.
      This assumes the TF MIDI settings are the defaults.If you are unsure, do a CLEAR SETUP or check that : "SYS ID" = 1,  "OUTPUT" = XMT.
      You may have to configure FactorLib to see your MIDI/USB feed. Wait until it is plugged in, the go to MIDI/config.
