Timefactor Looper External Midiclock Sync Drift
Home Forums Products Stompboxes Timefactor Looper External Midiclock Sync Drift
Viewing 0 reply threads
    • #106818
      gmcerveny
      I'm using the latest beta firmware for the timefactor and here are the setups I tried:
      Elektron MachineDrum mkI midi clock out -> timefactor
      Dave Smith MoPho midi clock out -> timefactor
      Both playing an internal sequence.
      Hooking either of these instruments directly into the timefactor looper with auto play enabled.  The first pass through they would be marginally close to on time, but after just a couple loops they would be noticeably off.  If left to play it continues to drift till obvious syncopations are present.
      Timefactor midiclock out -> Elektron MachineDrum mkI
      Timefactor midiclock out -> Dave Smith Mopho
      Using the timefactor as the clock source keeps the loops in time for extended lengths.  This is the setup I've continued to use as it's the only way I've found to keep it in sync.
