Home › Forums › Products › Stompboxes › Timefactor memory problem
September 1, 2013 at 3:09 pm #111068EtienneParticipant
my TF has a memory problem, a bug or a backup battery fault…??
I use it in Bank mode and when I power off then power on, it always come back in play mode.
My preset are still here when I go back in bank mode, but now I can't no more save a preset, when I push the encoder to confirm the save, it fails, something unreal appears on the screen (never the same thing), and then it's blocked, and I have to power on again, sometimes it power off directly…
Thanks for telling me what can I do to solve this problem, possibly not to loose my favorite preset.
Etienne
September 1, 2013 at 9:43 pm #124751
You can probably fix the preset problems by setting the unit to Factory defaults (see User Manual).
But, the cause of this problem is less obvious. It could be a faulty power supply – are you using the one that came with it ?
September 1, 2013 at 10:14 pm #124753EtienneParticipant
yes, I was thinking about restore factory preset, but I have to save my preset first, have to see how to do it.
I use a Cioks DC10, but the problem is still there when Iuse the original Power supply.
You think it's more a soft problem, not a battery fault, don't know if there's one ?
September 2, 2013 at 1:16 pm #135581
There is no battery. It just .. remembers.
Or to be exact, it should remember. Power supply issues can make it forgetful, but if it is not this, it would suggest a hardware problem.
September 2, 2013 at 2:10 pm #135582EtienneParticipant
ok thanks, I guess all I have to do is to try a reset after saving my preset.
I hope it will solve the problem…
September 3, 2013 at 9:35 pm #135591EtienneParticipant
so I 've done the initializing procedure, and the problem is still there, it bugs when I want to save a preset.
What can I do now, something that I can check inside or other things ?
Thanks again for answering.
September 5, 2013 at 12:15 pm #135592
Sounds like support@eventide.com. Sorry.
September 6, 2013 at 2:18 pm #135597EtienneParticipant
Good news, I've loaded the last version software and it seems that the problem disapear.
I can now save my preset and it remembers all the parameters.
I check my PS Cioks DC10, and it gives 8.69V, don't think that was the problem ?
I hope the problem will not come back again.
Bye !
