Timefactor MIDI Bypass
Home Forums Products Stompboxes Timefactor MIDI Bypass
    • #107159
      thom
      Hi
      I understand the new SW allows bypass using PCs. I am successfully using PC commands to select patches, which is simply a case of setting the Timefactor to receive on MIDI channel 1, setting my Musicomlab switcher to transmit on channel 1, and then PC change 1 selects patch   1:1, PC change 2 selects patch 1:2 etc etc, but how do you get the unit to bypass using PC command? Sorry if this is obvious but it would be greatly appreciated if someone could help out.
      Thanks
    • #120555
      Make sure you have the latest software. Then, there are extra MIDImap entries(after all the others, starting at 124) for
      TOG – TOGgles the bypass setting
      BYP – make it BYPassed
      ACT – make it ACTive
    • #120592
      thom
      That seems to work. I tried 124 which selected bank 62:2! (if I remember correctly). PC 125 sent the unit nicely into bypass however  so thanks 🙂
