Home › Forums › Products › Stompboxes › Timefactor MIDI CC
September 25, 2014 at 5:29 pm #111962
I am in the process of configuring a MIDI setup between my Timefactor, Timeline, and M9, where the TF is the controller. So far everything I have tried works great (syncing clock, each TF preset sending to recall a TL preset).
I currently have one switch of my E3D controller (tip, I believe) setup to bypass the TF. I would like this switch to also bypass the Timeline, but the CC only goes to 99 on the Tip? Timeline bypass is 102. Any way to make it work?
Also, this one may be way out there but I am pretty new to MIDI controlling, but any way to have the Timeline send different CC on different MIDI channels?
September 28, 2014 at 5:06 pm #126765Quote:… the CC only goes to 99 on the Tip? Timeline bypass is 102. Any way to make it work?
Currently, I can only think of additional hardware or computer-based software solutions. Or some future firmware update from Eventide. Many manufacturers around since the dawn of MIDI seem to prefer using 100 of the 128 available PC or CC numbers.
Quote:… but any way to have the Timeline send different CC on different MIDI channels?Both the Timeline and the TimeFactor operate on a single MIDI Channel. The TF can receive over Omni, but transmits over one channel from 1-16. I believe that you'll need to look into a dedicated MIDI controller for something like this.
July 11, 2018 at 6:58 pm #149677
Can the Timefactor still not transmitt higher than CC99? I’m trying to control a couple of pedals of which bypass is also 102:/
July 12, 2018 at 1:26 am #149678
Sorry – this may sound stupid, but we only had two digits to enter the CC, and thought 100 would be enough.
Given enough time, one can always be wrong.
