Timefactor MIDI works up until 13th bank
Home › Forums › Products › Stompboxes › Timefactor MIDI works up until 13th bank
Viewing 4 reply threads
    • #111290
      I slave my Line 6 M9 from the TF. It works perfectly until the 13th bank. No scene change. BPM data sent but doesn't not change scene on M9 like every other bank (1:1 to 12:2)
    • #125179
        You should check (if you have not already) the TX MIDI Map on the TF. If that is OK, the problem could be at the Line 6 end.
      • #125182
        What about the MIDI map? Thanks!
      • #125183
        How do I make the MIDI Map ok?
      • #135967
          To be sure that it is OK, you would either have to re-initialize the unit, or step through the lines that may be causing problems. Either way, some UM reading would be appropriate.
