TimeFactor, ModFactor MIDI Clock sync on preset change
Home › Forums › Products › Stompboxes › TimeFactor, ModFactor MIDI Clock sync on preset change
    • #111586
      Hello!
      I've just got my TimeFactor and ModFactor synced via MIDI clock, but I have a question!
      Is it possible to have the TF send tempo to the MF on program change, without re-tapping in the tempo? Currently it syncs only when tap tempo is sent to the TimeFactor (via MIDI – I am using a Disaster Area controller).
      Ideally, if i were to change presets on the TF which have different tempos saved, the MF would track along automatically, but this does not appear to be the case!
    • #125841
        Make sure that Global Tempo is off.
        There was a bug where MIDIclock tempo was not updated on loading a user preset. Make sure you are running the latest version ( 3.5.0[4] ). If this is not it, there is a new version due in a few weeks which should fix it.
      • #125842
        Global tempo being off on the ModFactor?
        Also, the TF is running the latest firmware, and the MF is running the new beta firmware.
        Thanks for  the reply!
