Hello!
When I load presets from TimeFactor via MIDI PC using MusicomLab EFX LE II, the programs load totally mute meaning there’s no dry or effect signal.
It’s not the MusicomLab loop issue because if I then change to different preset and back manually, it works fine.
The MusicomLab is not programmed to send any other MIDI messages, I think I monitored MIDI to make sure it’s not sending any CC accidentally, but I would have to check that again but currently unavailable to do so.
Has anyone experienced this? Is there a feature on TimeFactor that could even act in such a way, that could be accidentally called up by MIDI messages?
It’s a total problem during gigs as my sound mutes when I load presets and I have to fast manually change to another preset and back.
EFX LE 2 works fine with the H9.
Thanks and best regards,
Marvin.
