Timefactor Octaver Loudness
Home Forums Products Stompboxes Timefactor Octaver Loudness
Viewing 3 reply threads
    • #107410
      fkalich
      It really is significantly louder than the dry signal, surprisingly so.  Is there a workaround for this?  In order to take the Octaver volume down to a similar level with the Pitchfactor bypassed, I have to roll the mix of the wet signal down so low that the effect is mostly removed.  Or  back on the parameters that really are crucial to make the effect sound good, the two on the bottom right.  I am assuming I don't have a problem with my pedal. I have all three Eventide stomp boxes, and this is the only effect where I have this issue among all the stomp boxes.  This is really the only thing I have been disappointed with about the pedals, but it is kind of important to me.   I have held on to my Boss OC-3 because of this issue.
      Frank
    • #121058
      There will be a preset output level setting in the next release, due shortly.
    • #121060
      fkalich
      Thanks for reply.  Will that allow you to set outputs individually for each preset?
    • #132206
      AAgnello
      Yes. Output level can be saved with presets.
