Timefactor presets on an Eclipse??
Home Forums Products Rackmount Timefactor presets on an Eclipse??
    • #105349
      Can the Eclipse be programmed to get the exact same delays as the ones in the timefactor??   Also, will the Modfactor have anything the Eclipse can't do??  I have an Eclipse and was wondering if I am missing out not having a Time/Modfactor.  Thanks.
    • #116955
       Hi
      there are some peculiar fx in the TimeFactor that are somehow different from Eclipse:
      – Tape Echo
      – BandDelay
      – Filter Pong
      – MultiTap
      – Looper
      you can get similar results with the other algorithms.
      As for the ModFactor, there should be a Rotary unique to it.
      best
