Timefactor rebooting
Home Forums Products Stompboxes Timefactor rebooting
Viewing 5 reply threads
    • #109588
      Penno
      Has anyone else had issue this the Timefactor just randomly restarting ?
      I'm wondering if its a problem with the wall wart!!
      Penno
    • #124284
      If the wallwart is faulty it could do this. Either way, you have a hardware problem and should return it to Eventide (support@eventide.com) or your dealer.
    • #124287
      Marc Weyts
      I had the same thing happening to my Space. It randomly shut down and started again. Also parameters started changing without me touching anything. I did a factory reset and the problem seems to have dissapeared.
    • #124292
      Penno
      Trying a different power brick …. stable so far!
    • #124293
      Penno
      Its been running all evening on a line6 power brick and hasn't rebooted once!! Problem solved.
    • #124294
      Sounds good ! If it's still under warranty you could contact support@eventide.com and have them send you a new wallwart.
