Home › Forums › Products › Stompboxes › Timefactor sounds out of phase in Rectifier loop
December 17, 2010 at 11:56 pm #107483
7stringlespaul
MemberI am having trouble getting a good solid sound out of the time factor in the Rectifier parallel loop. I Compared to the sound of it true bypassed and there is an out of phase sound when activated. Switches on back are on line level. I tried killdry and it just sounds weird. I use a 25k ernie ball volume in the loop before the delay for nice swells. Any suggestions?
December 18, 2010 at 12:21 am #121221
One would normally use KILLDRY in this application – it is why it is there. You may have some other problem. Try it without the volume pedal.
December 18, 2010 at 12:28 am #121222
7stringlespaul
MemberI get a big volume drop when I switch to killdry, is that normal? I'm about to drive over to Mesa Boogie and get my triple rectifier modded for a series loop, is that a good idea? Would that solve most problems? What do you guys think?
December 18, 2010 at 12:48 am #121223
goldglob
MemberDigital pedals delay the signal a bit (A/D and D/A conversions) such that it will be out of phase with your straight through analog amp path. Parallel loops are a hangover from the past when most pedals were analog and it was thought that having your main signal un-effected would maintain purity of tone….nice in theory but not with digital. You need a series loop (or parallel set to 100% loop, which amounts to series). Then the dry signal goes through the pedal and actually gets digitalized as well as the processed part, so no phase problem.
December 18, 2010 at 2:09 am #132381
goldglob
MemberThat's a good idea; wish I could just drive over to Mesa Boogie, then again, here in London, I can just drive over to France. Back to loops: some time ago I had my 2001 Laney LC15R loop modified from parallel to series and just noticed that their latest version, the LC15-110 has indeed a series loop. They're slowly getting it. Another thing, ask whoever modifies your loop to check that your reverb send is post loop: with the Laney, that had to be reconfigured as well.
Merry Xmas.
December 19, 2010 at 12:51 am #132382
7stringlespaul
MemberThanks for the help. I went to Mesa in Hollywood to get my loop modded, ended up buying the new multi-watt Triple Rectifier with the series loop. Sounds much better!! They are modding the older one for me too, but I will probably sell it in a few days.
December 19, 2010 at 12:52 am #132383
timothyhill
MemberIf you're getting a big volume drop when active and bypass when using KillDry, you're send/return levels on your amp may be mismatched, or the instrument/line switch on the pedal may be set incorrectly. With my DualRec, I usually set the send and return levels to 50%, set both switches on the pedal to Instrument, and turn KillDry on.
Another option is to set the amp's Send to 50%, the amp's Return to 100%, both pedal switches to instrument, and KillDry off. Setting the amp's return control to 100% makes the loop perform like a series loop.
Goldgolb hit the nail on the head with the explanation why.
