TimeFactor – SPILL Question
Home Forums Products Stompboxes TimeFactor – SPILL Question
Viewing 3 reply threads
    • #114472
      spindlebox
        Hello, I know it is possible to have SPILLOVER between presets, but I THOUGHT there was a way to have the delay continue after you pressed it to bypass, so that when you DID press it off, the delay didn’t cut off abruptly.
        If so, how do I set this up?  I did look in the manual and only saw the SPILLOVER thing between presets.
        Thank you!
      • #147713
        gkellum
          Yes, you can do that.  There are different bypass modes for the TimeFactor.  The bypass mode DSP+FX will do what you described.  It's in the TimeFactor manual on pg 19.
          https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/TimeFactorManual.pdf
        • #147715
          spindlebox
            Thank you so much!
          • #147717
            spindlebox
              OK, now since I have your attention, one more question, and you could point me to another page in the manual:
              When using a PRESET in the bank; i.e., 1:1 – can I adjust the TAP tempo?  Sometimes using the preset, my drummer will get slightly off from me, and I need to adjust.  Is this possible?
              Thank you!
              • #147718
                gkellum
                  Yes, if you long press the TimeFactor's right footswitch that switches between one of two modes: play mode and preset mode.  In play mode you can tap in the tempo with the right footswitch.  This is described on pg 37 of the manual.
                  If you don't want to mess with switching between modes, you could use an aux switch instead and dedicate one of the switches to tap tempo.
