Timefactor tap input to generate midi cc to a T. rex replica
Home Forums Products Stompboxes Timefactor tap input to generate midi cc to a T. rex replica
Viewing 4 reply threads
    • #111151
      kenriley
        Hi
        I'm trying to sync my delays with a combination of external jack & midi and I can't seem to find a solution in the manual or forums.
        Is it possible to control timefactor tempo via the external tap input and for it to send out a tempo CC to my replica via midi?
        I don't have a midi controller and want to use a multi tap pedal so I can also sync an empress tremelo2 and my delays very simply.
        Thanks
        Ken
      • #124918
        kenriley
          So I've been able to generate the midi CC out when I use remote tap into Timefactor. The Replica sync is sporadic at best, I guess the problem is that when the aux triggers a CC there may be switch bounce or certainly a non buffered pulse.
          I've read and re-read the manual and can't find how to use the tempo within timefactor created by aux in to send out a corresponding CC.
          Is it possible?
          Cheers
        • #124919
            Sorry – don't think there is a way to make it send tempo values as a CC. MIDIclock out is the nearest it gets.
          • #135745
            kenriley
              Does timefactor have some kind of buffer arrangement so that aux tap ignores switch bounce etc? If so, is it possible to employ this for midi cc generated from aux too?
              thanks
            • #135748
                There is some de-bouncing on the switches. You'll have to check and see if it meets your needs.
