I have just got a 3 way auxillary foot switch from Red Onion, (highly recommended). This works fine. I prefer to use my Timefactor in bank mode, so it operates like a multi fx unit, switching between saved presets. My aux footswitch is set currently so tip decrements bank number, ring toggles the infinite repeat on and off, and T+R is tap tempo. It works great, but my queston is can someone clarify how tap tempo works in bank mode considering that there are 2 delays on the timefactor. Is there an option in bank mode that allows tap tempo to retain the ratio of delay between delay 1 and 2, or does it just make both delay times the same. What are the options?
Thanks
thom
