Timefactor ; The pedal works but the effects are away!
Home Forums Products Stompboxes Timefactor ; The pedal works but the effects are away!
    • #111658
      Swepedal
      Hi!
      While checking out the different settings on my timefactor all of the delays has "disappeared"… Everything is correct, and it worked one hour ago but I seem to have changed some setting that makes the effects silent.
      Is there any specific settings I should check out to try to get it back?..:) Should I restore the settings?
      Thanks a lot in advance!
    • #126018
      gkellum
      Is your TimeFactor is bypass and just playing through the dry signal?  The left footswitch toggles between active and bypass in performance mode.  If you're in preset mode, it will load the first preset in the bank instead.  You can long press the right footswitch to switch from preset mode to performance mode.
      If you wanted to restore your TimeFactor to its factory presets, you turn it off and then turn it on again with the algorithm selector dial and the middle footswitch pressed.  Then, you'll have all of the factory settings restored, but you'll lose any presets you might have had saved on the unit.
    • #126019
      Make sure you are plugged into the right inputs (see UM).
