timefactor updates wont show up in update window
Home Forums Products Stompboxes timefactor updates wont show up in update window
Viewing 10 reply threads
    • #113832
      kwikc4
      My update software sees my timefactor but the new updates dont show up?  Can I get the 4.5 update to manually enter in?  I need my timefactor to work with h9 software.  thanks
    • #141301
      gkellum
      Ok, I emailed you the latest bam.  (The latest bam is 5.2.0[6], and only v5 and above releases work with H9 Control.)
      We should have the update server back up and running soon.
    • #141302
      kwikc4
      thanks
    • #141305
      kwikc4
      update went well thanks, but when I startup h9 and try to log in its says server is under maintenance?
    • #141307
      gkellum
      Please try now.  It should be ok now.
    • #141313
      xdadex
      Hey gkellum,
      I’m having the same issue. Could you send me the newest Timefactor update to manually load?
      • #141320
        gkellum
        xdadex wrote:
        Hey gkellum,
        I'm having the same issue. Could you send me the newest Timefactor update to manually load?
        Ok, I just emailed you that update.
    • #141324
      engnerkn
      Can i get latest manual update to my email for timefactor because im having the same problem.
      thanks
    • #141327
      gkellum
      Ok, I just emailed you the update file.
      Incidentally, we should have new versions posted tomorrow of the Eventide Direct Updater (v1.7.0) and H9 Control (v2.5.0) that download the update files from the cloud.
    • #141334
      nichenderson
      Can I also have the update? I can’t seem to get this work 🙁 Much thanks!
    • #141343
      gkellum
      We’ve posted new builds of both H9 Control and the Eventide Direct Updater that get the updates from the cloud. So please update to the latest version.
    • #144922
      Rafael Santos
      hello, I have the same. Can I get the same 5.2 update too?
      • #144923
        gkellum
        Use the Eventide Direct Updater app.  It has the latest software releases in it.
  • The topic ‘timefactor updates wont show up in update window’ is closed to new replies.
