Home › Forums › Products › Stompboxes › TimeFactor – usb not working as it should.
- This topic has 5 replies, 1 voice, and was last updated 6 months, 4 weeks ago by
gianlucaridolfi.
May 2, 2015 at 8:12 pm #112552
hey guys !
I got it second hand,it had firmware 3.0.0
I connected it to my PC (usb) to upgrade it,I installed all the necessary software on my PC,at first the pedal d couldn't be recognized and after I connected/disconnected the usb cable on my PC a few times it got recognized and I upgraded it successfully.
Disconnected the usb and started working on it for a week or so,meanwhile I got a the Space pedal too! Later I thought it would be cool to save my presets on the PC instead on the pedal and start creating a library and so I connected a usb cable with the pedal but no luck,the PC (WIN7) recognized an UNKNOWN device,I changed lots of usb cables ,usb ports ,different computers ,3 in total PC,nothing.At the same time I have the Space pedal working with usb fine,the H9 software connects to Space immediately.
Lately I have another strange issue,when I turn on the Timefactor Pedal I get the message "UNPLUG USB" ,the Active led stays off and the pedal does NOT work and the screen shows the selected algorithm ,the strange thing is that I get this message while I don't have any usb cable connected to the pedal !!!!
So I have to turn off the pedal,connect a usb cable to the pedal and then all works good,but still the pedal is not recognized by my PC.
anyone else experienced something similar ?
any advice ?suggestion…????
thank you.
May 15, 2015 at 4:59 pm #139070
I guess this must be a very strange case….. 🙂
May 15, 2015 at 5:52 pm #139074
Sorry – this is a known but rare problem. It will have to come home to be fixed – hopefully you are still under warranty. You should contact support@eventide.com
September 16, 2018 at 7:27 pm #150096
I have the same problem reported in the post above. There is already a solution?
March 25, 2019 at 10:58 pm #151557
Same problem with my MODFACTOR.. Power up get UPLUG USB, when there is no USB in the unit and effects don’t work.
August 20, 2025 at 7:05 pm #191669
Il mio Time factor ha smesso di fare il delay e non si collega più tramite USB, ho ripristinato il pedale alle impostazioni di fabbrica ma niente non vuole più fare il suo lavoro
