Home › Forums › Products › Stompboxes › Timefactor Wet/Dry to Normal
July 9, 2021 at 2:02 pm #116570dariettsParticipant
Hello!
i need your help:my timefactor has the wet/dry setting which gives me the impression of losing “attack” in the clean sound of my guitar. I would like to change the knob setting but on my pedal, in the system mod, i can’t find the “Routing” menu and i don’t know how to do it. Someone can help me??Thank you! -
July 9, 2021 at 2:05 pm #158205darietts wrote:i can’t find the “Routing” menu and i don’t know how to do it. Someone can help me??
In system mode, find the UTILITY category and ROUTING should be the first option. As a reminder, the System Mode Navigation menus/parameters are as follows:
1) Push the Encoder to step down into the menu tree.
2) Turn the Encoder to scroll thru menu items or parameter selections or values.
3) Press the Middle Footswitch to step up the menu tree to upper level menu options. -
July 9, 2021 at 6:44 pm #158207dariettsParticipantjoecozzi wrote:darietts wrote:i can’t find the “Routing” menu and i don’t know how to do it. Someone can help me??
In system mode, find the UTILITY category and ROUTING should be the first option. As a reminder, the System Mode Navigation menus/parameters are as follows: 1) Push the Encoder to step down into the menu tree. 2) Turn the Encoder to scroll thru menu items or parameter selections or values. 3) Press the Middle Footswitch to step up the menu tree to upper level menu options.
There’s no Routing in my system mode, i’ve already search for it.
Can be related to the sw version?
July 9, 2021 at 6:54 pm #158208darietts wrote:Can be related to the sw version?
Very likely. If you navigated to the UTILITY portion of the system menu tree and you’re not finding ROUTING then you may have an older version of the firmware. I would connect your pedal to computer via USB and use H9 Control to update the software.
